80sonvinyl
Member
Hello everybody and welcome to my first post on this forum.
I have been in a battle with IGD since I got into this hobby 3 years ago, and since purchasing a Technics sl1500c with a VM95ML during the summer, it's been reduced, but hasn't gone away.
I have many records that play with varying degrees of IGD. Loud instrumentals/vocals sound awful on some records, especially as I listen a lot through headphones. Then I have loads that don't play with any issues, but I'm getting it on enough records to make me paranoid, let me say that. I've gotten to the point that I wince at the thought of me putting on a heavy metal record or something- I'm not into that but I feel that if I were, my turntable wouldn't play ball...it's bad enough on rock/pop.
About one in 5 or 6 used records I buy will have it, and I'm picky about condition. Some used records I've gone through three or four pressings to get one that doesn;t play without distortion.By the way, this isn't 50s or 60s stuff either...it's 70s and 80s vinyl. Also, I used to think that it was just a problem on used vinyl, but earlier today I stuck on a 180g record I bought new and guess what, there was a hint of it on that. Maybe they're all bad pressings but I don't know...is this common?
I have aligned my cartridge with both a printed Stevenson protractor and the Technics overhang gauge. Nothing makes a difference. I have played with both ends of the VTF scale. VTA also makes no difference. The turntable is level. Preamp has also been eliminated as the source of the problem.
I swapped out my VM95ML stylus and stuck on my old VM95E..same issues so it's not the stylus.
I was told by a few hifi dealers that if some records play fine, then it's not the TT, but I'm kind of not convinced. But if it was my turntable, then what on Earth would be causing it? It's basically new. But I'm fast coming to the conclusion that either a) my TT is incapable of reproducing loud pieces of music (especially at end of sides), or b) the Microline styli are not all they're cracked up to be.
Yes, some distortion I hear may be subtle enough to be overlooked by other listeners, but also I have some records where it's unmissable and would give you tinnitus! I regret that I haven't the technology to upload needledrops, basically it sounds like a hissing/crackling on loud bits. Sometimes in left channel, sometimes in right, sometimes both.
Sibilance, interestingly, is not really an issue for me, only on a select few used records. But high frequency distortion is ruining my enjoyment of the hobby.
Thanks for reading...I really hope someone can help me out. All stores are closed where I am due to restrictions.
