WopOnTour
Hoarder Extraordinaire
Alignment with the headshell is not neccessarily a good thing.In fact it can often be the worst thing you can do (depending on the arm design) and CAN result in an incorrect offset angle, poor tracking and increased distortion. It's the alignment with the arm's arc and playing surface that matters. Bad alignment can result not only in bad sound but also results in accelerated wear in the stylus and LP groove damamge.So, I think for the money, the MLa is a pretty safe bet. Obviously, make sure you get it aligned with the headshell as closely as nyou can. Good luck with it.
You should use some sort of protractor to get correct alignment.
The link below is a generic one for a typical straight 9" (228.6mm) arm from Feel The Music dot com with null points set at 70 and 127mm. You should be able to "land" your stylus on the null point target dot (without moving the turntable) and resulting in the cartridge staying in alignment with the guidelines.I beleive this one is based on an SME arm, so by measuring your own arm you can create more accurate null ponts for YOUR arm using a Baerwald or Loefgren calculation (or a spreadsheet that simplifies these) that you can download at Vinyl engine or FTM here: http://www.enjoythemusic.com/freestuff.htm
http://www.enjoythemusic.com/protractor2.pdf (hit REFRESH if the link wont work OR copy and paste into your browser)
WopOnTour
Note whe you print this make sure you dont have "fit to page" selected so the dimensions are correct
