Definitely more things to fail. And for that reason I'd be cautious about using it when a thermistor will do the job just as well.May add more solid-state complications to the tube circuit.
More things to fail?![]()
But since we're discussing that particular timer, a simple improvement to that circuit, IMO, would be to use an electronic switch (a Mosfet or BJT) with an R/C controlled gate or base voltage that ramps up over some time interval, and when that voltage is at the relay's threshold value, the relay kicks in and closes the circuit to short out the 10 ohm current limiting resistors. It may be even simpler than that by replacing the relay itself with a transistor. I'd be surprised if such a device does not already exist for controlling a 120V mains line, and I would expect they shouldn't be that expensive. Anyway, just thinking out loud. I've never had a deep need for a time delay circuit in a tube amp.
