Is it Possible
oilsmoke
to have 4, 8 ohm speakers wired to 8 ohm? Like 2 sets of wires Parallel (4ohms) than wire those sets in series? 8 ohms would this work?
Yes. You could also wire each pair in series for 16Ω then wire those pairs in parallel to each other for the same 8Ω result.
It works with squares: 3 sets of 3, 4 sets of 4, 5 sets of 5 etc. All bring you back to a net 8Ω load when using 8Ω drivers.
Some stage back line gear such as bass cabs are wired that way. But that’s stage gear. For hi-fi, parallel is the only way to go for both raw drivers and speakers in enclosures with crossovers.
