vintage 5.0
vintage 5.0
I have a Aragon 4004 MK II. Can I run two sets of speakers in parallel. One set is 8 ohm and one is 4 ohm. Will that work or is there a possible risk to the amp from doing this.
Thanks to all of you that is the info I was looking for. I do not listen to loud music at all. Mostly some country, strings, female vocals and of course some rock. That makes sense to me. I just wanted to make sure I would not hurt the amp or blow a fuse or something. Thanks again that was very good information. Would I be better to run two pairs of 8 ohm speakers?
Two pairs of 8 ohm speakers in parallel is a 4 ohm load to the amp. Most good amps are robust enough to hand that kind of load without damage. But it would better if the amp is rated for 4 ohm loads. I believe your amp is rated for loads down to 4 ohms. You would be better off with two pair of 8 ohm speakers.
The Aragorns he has are actually billed as stable down to 1 ohm, that is, they will continue to produce more power down to that impedance. At 4 ohms they produce twice as much power as at 8 ohms. In other words constant voltage down to 4 ohms. The voltage will drop after that as the impedance drops but the amp should not misbehave. Although as already pointed out by toxcrusadr, the heat sinks should be checked..
That is so funny my close friend has a set of the Krell KMA 160s those are some serious metal. They get so hot and use some power. I think they are real impressive amps. I bet you like having those around.
