mfrench
Addicted Member
oh, yea, the B-61 platter weighs more than 8 Lbs, seems more than the others?
I think you're right; and, it seems like a bit of a harder alloy?
It's been a few months since I found my L75 in the garbage and still no progress. Plenty of house projects are keeping me busy, so hopefully the Lenco will get revived after the summer.
Anyone else with new Lenco projects on the go?
I pulled the B-61 out again today, Platter, A Harder Alloy?, i took my hard mallett and gave it a soft, then little bit harder tap, WoW?, Yes, Seems to ring higher/longer than th 75, Maybe a harder alloy?(Casting Chiefs blend?) or just thicker/heavier?(8Lbs).
Any updates Steve?
I finally got off my posterior:
Lenco PTP5 in soapstone with Jelco SA-750D and Midas DL-103. Mat is TTWeights copper/maple laminate and weight is also a 4lb TTweights jobbie. The second from last shot shows it on squash balls mounted in lengths of PVC pipe. That didn't work well. Last shot is on purpleheart blocks. I plan to try a couple of different types of wood to see if there's any difference/benefit.
Niiiiice!! :yes:
That PTP5 is slick! Did you cut the soapstone yourself?
I just reserved my spot in line for a Superbearing today...
That's a very cool looking mat. Keep us posted on your isolation comparisons. :thmbsp:
Steve
Hopefully I'll have some time to experiment in the next couple of months. We have a big overseas move looming, so I probably won't have much time. Sometime in the new year is more likely.
I hope there's some time after the move. Lots of time.
