@merlynski , do you mean these 2 red lines connecting to ground?
I just happen to put the ground in that particular spot. It does not mean connection.
Sorry to create any trouble here and thanks for all your input and help.
@EC1
No, I am not referring to the red lines, I was referring to the blue line between the word 'GROUND' and connection dot on wire between the resistor and the BLK labeled transformer wire (outlined in turquoise rectangle, below). To me that clearly indicates a connection between that wire and 'ground', which is the chassis in most audio equipment, including your Onkyo (I checked the schematic).
Since you used similar labels on the wires "To switch" to mean a connection, I took the same meaning for the word GROUND.
The red lines I understood not to be connected (to GROUND), by the color and the break across the word. Schematics have drawing conventions which are understood by those who know how to read them. You stated you had no experience with electronics, so, taking that into account, I knew you did not understand the the conventions, but I did not want anyone to use your drawing, thinking it was correct and safe. Like 50 Green said "Mains power is not something to guess with!"
The symbol in the green circle in the image below means it is a common chassis connection, often called 'ground'. The 3.3MΩ resistor will bleed off static charges but will not pass enough current to be hazardous, even if that wire were plugged into the HOT side of the outlet.
In your drawing, when the amp is plugged in, if the triac turns on, the HOT side of the AC line could be connected to the chassis through the transformer primary. If a person was to touch the chassis and a real ground or a neutral connection, enough current could flow to cause a fatal shock. Connecting the amp to another unit through an audio cable could put that voltage onto another unit's chassis or ground and damage the equipment.
Please understand this is not a personal attack at all, but I saw a potential lethal wiring mistake and could not just let it pass. I hope my drawing helped you understand the correct way to wire the triac.
