Issue with SA-7800
d27 is a diode on the other side of the board .. d means diode ...
Okay well its still marked with "27" right? I get 0.00 either way....i Mean one end is sticking out the bottom (that I showed you a pic of) and I also measure 27 on the other side (same component right?) and still got 0.00
fu2 .is fuse number 2 .
just been looking at the pics again and see the fuse holders look like they have been getting hot where they enter the board . clean the fuses and holders .
I just saw that in the service manual Pete.... can I ask you... are these 3 fuses are they all 8 amp or what should my reading be? Maybe I haven't checked them correctly?
crash course on some component id codes .
R resistor
D diode
T .TR .Q transistor . not strictly true but most have 3 legs .
C capacitor .
L coil or inductor ..
SW switch ..
Okay so.... can you tell me the correct way to measure the fuses? I thought I was doing this right but maybe not? I have red & black on each side and set to the "continuity" setting on the MM.... well on the 6amp I get a "1" reading and on the .8amp I get .01 on both???
they look ok . now try fuse holder to fuse holder with fuse installed . this checks to be sure the fuse is connecting to the holder .
yes of course .
it can however be done with power on and measuring volts . and actually a better way to test . but ups the odds of something going wrong .
Also... what do you use to clean these components? I ordered some "deoxit" because I had heard it was good stuff... good idea?
