Issue with SA-7800
Okay, so I think I may have found some (4?) diodes in this picture... which one is d27 though? You can also see the fuses at the top of the pic. Also, what is that white rectangle directly below the bottom most fuse with the metal piece on top that says "577" on it? Because it looks like from the schematic d27 should be right about there?
That "rectangle" is VFD filament transformer. It feeds tube filaments with AC voltage (arround 3V). In order to identify components on PCB follow the schematic from test point to near part using your digital multimeter in diode or continuity test mode.
@petehall347 as someone you helped out several times in the past I just wanted to say your input in this thread is awesome. I hope the OP appreciates your considerable help and remembers that a little patience goes a long way :)
I can't thank Pete enough and I do hope he knows that. I've already learned way more than I ever knew and even if we dont get it fixed i'm eternally grateful for the knowledge. :)
Okay so here are the correct AC readings for the diodes now that i know where they are:
D27 (cathode) - 141.5
D27 (anode) - 47.3
D28 (cathode) - 141.8
D28 (anode) - 47.3
D29 (cathode) - 47.4
D29 (anode) - 0.00
D30 (cathode) - 47.3
D30 (anode) - 0.00 and -0.00 (fluctuates between the 2)
I'm not good at reading these schematics... they seem to be right next to each other on the highlight path... is this correct? Also do I measure in ohms on the same side i measured the diodes or on the joint side?
you go point to point . hold the probes together to see what reading you get . then you will know what reading to expect between 2 points .
yes that is the correct points you marked out . go on the solder side then you can visually see the copper traces .
