Issue with SA-7800
ok . now we to rewind back to where the misunderstanding about diodes and test points happened . and get those voltages at the diodes .
part of the confusion comes from here ....
TP is test point . otherwise known as pin .
i know you will be confused by that but will figure it out later ..its not important right now anyway .
you were in the wrong place . its ok though . just get on the same page and we will find the problem .. page 34 in the service manual .
Service Manual I have is only 29 pages
-edit- nevermind... was looking at pdf page numbers... okay i'm on pg 34... what am I looking for?
Okay so this is only "27" i see on the board... it is to the right of the heatsink and right next to the big black capacitors...is this not it?
Okay, so I think I may have found some (4?) diodes in this picture... which one is d27 though? You can also see the fuses at the top of the pic. Also, what is that white rectangle directly below the bottom most fuse with the metal piece on top that says "577" on it? Because it looks like from the schematic d27 should be right about there?
