bswinehart
Hi Lokerola,Nice work - the graphics came out great.
Would you mind sharing the .pdf file you created for the 4311 foilcals? My email address is robert.swinehart1@gmail.com
Thanks!
EF , just ordered the same caps to upgarde my 4311b ,how is the sound with these ?This thread has been immensely helpful. Thanks everyone!
Heres what I've put together.
Hi Lokerola,
Thanks!
I would trust the JBL manual on the proper wiring for the 4311b. It sounds like the previous owners already messed around in the speakers, considering that there was a rotated woofer and a replacement tweeter. It doesn't take much effort to change the wiring on those speakers, so just go by color-- Red wire to red terminal, black/green wire to black terminal. I would pull the midrange as well and make sure it is hooked up correctly as well, as well as pulling all the drivers on the other speaker to make sure everything is connected properly.
Thanks for posting that thread @Thrifty HiFi . It really seems to be somewhat confounding as to what jbl intended with the woofer polarity.
The red terminal is almost universally the positive one. After checking the manual, it also shows the drivers from the back side with the wiring diagram and the driver polarity, so you can use that as a reference as needed. Just make sure that all drivers are connected identically between the two speakers for now. I would stick to what jbl did originally for the tweeters, but you can experiment with woofer polarity if you like, as long as you change the driver's polarity so they match each other. IMHO, I would stick to what Jbl did originally for the woofers as well.
This might have been asked before ,apologize if that's the case, the capacitors on the 4311xx series are Non Polarized ?This means that we replace with non polarized right?
Just making sure i ordered the proper ones (Jantzen Ones)
Thanks ,I am going to try and upgrade the crossover myself ,looks not that difficult.Yes, crossover caps are non-polarized.
Ciao Glenn,
that's a good idea, thank you! I think I will delay attempts to when I have extra speakersI am dealing for a pair of L220
which needs the passive to be refoamed and also some fixing to a crossover, if I menage to get and resurrect them I would sure give a try at recapping the 4311B and follow all of the precious advice out of this thread.
Grazie
Giovanni
