HOLY MOTHERLODE!!!
No, I'm not talking about the SWTP Amps. Its picture no. 3. That's a photo of a JBL SE402 Solid State Energizer. Its one of JBL's first SS power amps used as an integrated power amp for a speaker. I can't even find anything on it yet except a relationship to the more common SE400 SS Energizer on JBL Pro Customer service. I suspect its an active equalized crossover amp? Zilch will have to help me out. Here's a link to the manual for the SE400:
http://www.jblproservice.com/pdf/Vintage JBL-UREI Electronics/JBL-SE400S_SE408S.pdf
This manual will tell you how to hook it up.
This means your Paragons are one of the more rare versions that is self powered. The amp is usually a fair amount alone.
In fact, Zilch has helped us out by this LH post and thread:
http://audioheritage.org/vbulletin/showthread.php?p=122859&highlight=se402#post122859
http://audioheritage.org/vbulletin/showpost.php?p=122857&postcount=11
"SE400S is silicon transistors, with "T" circuit. Earlier SE401 is germanium, as I recall.
My SE402, the installed version, is EQ'd for an 080 system, whatever the heck that was. Extremely rare, no doubt.
And I'm sure the germanium sounds better to discerning ears.
BUT, I'm representing the buyer here....
Edit: Indeed. C55 w/dual 150-4 & 375, apparently:
http://www.lansingheritage.org/image.../page28-29.jpg"
The JBL 080 system of Dual 150-4 and 375 is the Paragon type load except one woofer per channel.
From Dave (norealtalent) on LH in a subsequent post:
"From the CA-400, Instruction booklet for the JBL solid state energizer,
"*The two models are identical in operation. Model SE401 is supplied for installation in existing JBL enclosures. When the Energizer is factory-installed, it is designated SE402."
Yowsers!!
It wasn't the extra amps but the amp already built into the Paragon that is the true icing on the cake. CONGRATS AGAIN!!!
DOUBLE SCORE!!!
Regards,
Bart
