Where can i get JBL grills on the cheap in Michigan? Im missing the whole grill (except the white things in the speaker ), and id like the square grills, but doesn't matter.
From the OP's other post, I'd assume that he has L100's...and you won't find grill frames nor grills for cheap anymore. With the grill frames you could build a smaller frame to drop into the grill frames and cover with grill cloth fairly easy. I've built them and they look just fine...just not original. I could post a picture or two if it would help.
