reclothing grills
brad6285
AK Member
im buying some jbl l112 speakers and want to have the grills recovered in he brown jbl color is there anyone on the forum that recovers them. thanx brad
A lot of guys here have recovered their grills. Do you have the original frames? If so, you can order a similar cloth or look around in your area for similar cloth and recover them yourself. It is a fairly straight-forward task. If your skill level is such that you don't want to tackle it, hang in there until someone from your area posts a suggestion as to where to go.
Here is an example of cloth:Parts Express brown cloth
If I didn't have a half dozen AKer projects in que, I'd offer to do it, but I'm sure there's someone closer to you that would volunteer. As Lance mentioned, hang in there, someone will eventually chime in.
If "JBL Blue" possibly interests you, our own foumite member "Zilch" has the factory correct JBL Dark Blue Grillcloth, and this is the exact same original JBL Sourced Grill Cloth that is used on all professional JBL 4300, and 4400 Series Studio Monitors.
Zilch can also be found in the Lansing Heritage Forums. Mark
I'd like to add Brad, that over on the Lansing Heritage Forum, there are quite a few threads about Grill Cloth installation, one very good one, describes the Contact Cement Glue being brushed onto the rear edge of Grill Frame (two coats) letting dry, then the Grillcloth is pressed into the dried glue with a warm-hot clothes iron.
It further explains, that with the use of masking tape, one can then apply a very neat, straight edge of glue upon the Frame's rear perimeter edge, and that after the Griil Cloth has been installed, that a metal straightedge, and utility knife can be used to then neatly trim away excess Grillcloth to finish the project.
This is just a brief description of the method described there, it appears to be a much neater, more professional method, and as well seems to bypass the mess that is often caused-associated by spray contact adhesives. Mark
Of all the odd places I was told that places that frames pictures would build custom framess (like to fit speakers) and sometimes even put the cloth over tham! I have never tried this- just wanted to pass along.
DC
The OP, hopefully, has the frames. These were the JBL's with the sculpted frames: http://www.lansingheritage.org/images/jbl/catalogs/1979-home/page4.jpg, not that a guy couldn't make a new set of frames and cover them with whatever color liked better. The JBL L112 Century II was available with two other colors, rust and tan so that could also be an option. This thread shows pictures and descrptions of the process:http://www.audiokarma.org/forums/showthread.php?t=192204&page=2 ,Post #30.
Max Z, I'd offer up the service, also, if I didn't have other projects that are keeping me busy and all the others that are on hold. BTW, just a hint to keep you extra busy: did you get Nate's EPI's, yet?:D No need to answer, I'll give you a call around the weekend.
Jo Ann's Fabrics has some very high quality speaker cloth, I like it much better than the Parts Express cloth. I know they have black and I thought they had a brownish-tan also, but I visited several fabric stores before settling on Jo Ann, so maybe it was somewhere else. It had a really nice feel to it and was quite heavy. You could see through it, but the PE fabric does appear to be more acoustically transparent. Jo Ann puts out coupons and their regular price of $10/yd is pretty good as is. Now to find the time to actually install it...
What is it called? I was looking on their web page and couldn't find any. I mean to they call it speaker cloth or is a specific type of cloth that goes by another name? I have several speakers that I need to do and would love to be able to buy something locally. What kind of glue have people used and to what success?
The cloth did have a product number, but I don't think I kept a record of it. I'll check. If you call a Jo Ann fabrics store and ask them, they will know. I just walked in and asked the cashier if they had speaker cloth and she took me straight to it. They know what it is. The cloth is quite unique, the way it hangs and its heft, I don't think it is a cloth that people use for any other purpose.
