There were 2 versions of the L100. One was based on the 4310 Control Monitor and the later model was based on the 4311 - slightly different drivers and crossover.
Check out the different versions here:
http://www.audioheritage.org/html/profiles/jbl/l100.htm
I'm not sure whether "Century" designation is very good at discriminating among them. I have seen even the older ones with vertical drivers (the 4310 version?) that had the "Century" name on the foilcal.
I think a better discriminator is that the older vertical ones were called L100s and technically, the ones with the woofer and tweeter offset to either side, were L100As.
thanks.
Here are the speakers i found over the weekend and wanted more info on, thanks again folks.
You can recap the crossovers, or upgrade them. See here:
http://audiokarma.org/forums/showthread.php?p=5639710
http://www.audiokarma.org/forums/showthread.php?t=106180
They sound great, and appear to have no issues, but one thing I noticed lately, is the the woofers, at times, vibrate to a scary point, and it's not just with tracks that have a lot of bass, or in response to bass thumps. It appears to be pretty random.
Does this occur when you're using a turntable? The 123A-1 will do a nice job as a transducer for solid bass but it reproduces what it's sent. In the case of use with a turntable that could be rumble from the table, the LP, or room vibrations or other t/t placement issues.
If this is the case, simply try it with another input like a CD and see it it helps. Doesn't sound like it could be caused by the speakers but the result could be damage to the speakers.![]()
Sure they're from the age of vinyl but they're also from the age of rumble filters! It can come from the record itself, or the table, or the room. Make sure your table isn't causing it internally. Check with a blank vinyl side or a long lead-out groove. Then try isolating the table with some damping material, a better shelf, a huge lithography stone, or squash balls cut in half. Anything is better than nothing. It could even be "feedback" from the speakers to the turntable. You're not setting the table on top of the speakers, are you?Why can I super crank the CDs and not the vinyl?
