@Dale Hobbs10-15 minutes of practice with a soldering iron is probably all you need to learn how to do a simple crossover. YouTube University offers classes every day.
I think removing the foilcal without damage is a bigger challenge.
It doesn't have to be pretty since it will be inside the cabinet. I would recommend testing them outside the cabinet (run long wires through port tube) until you are sure they are right.
I thought about this same project years ago before I sold off my L100s. I would try the Dennis Murphy version over the TG version.
Last but not least, keep the old crossover intact just in case you go to sell them and someone wants to revert to original (or use as an excuse to beat you up on price). Ditch the old twist-style speaker wire connectors and replace with decent 5-way binding posts if you didn't do it already.
Is that photo the same as this?Thanks for the reply. Sorry, newbie here..whats the foilcal? Also, are you familiar with this crossover from Laspada Audio for the
I found it was much easier to get nice looking results if I gave myself lots of room on the board. That board was 7×10".Nice work.
My vanity refuses to show my sloppy result.
I never looked to see what the overall DC resistance is. Loud speakers see an AC music signal. Here is an impedance vs. frequency sweep. Overall Impedance is the black line, blue line is the woofer, red is the mid-range, and green is the tweeter.I notice your mid circuit has 3.5 ohms of r. Does that much resistance de-emphasize the mid presence? What is your overall ohm reading at 5 ways?
The audio signals that pass through these crossovers are AC, not DC. The idea that parallel crossover components matter less than series components might apply to DC circuits, but not AC circuits. In an AC circuit, all components can effect the sound. At least, that's what I've been taught.I am sourcing the inductors from Madisound. They will unwind inductors that are too big for a small up charge which is fine with me. They indicated that the parallel caps, inductors and resistors aren't as critical with the actual sound quality as compared to the series elements? Sounds like C1021, C2081, C3061 could all be a basic capacitor like a Dayton or Bennic, and then the series elements C2011, C2031, C3011 and C3031 could bump up to a clarity cap or some other. I've heard that the Solen and Dayton may sound a little harsh. Who know if that is real or BS?
Years ago, when I first got my L100s, I used them with a Marantz 2230 receiver. It still works today. Here's what I've been able to learn about the 4312c speakers that might help answer your questions:I know this is an old thread, but still valuable. Are the crossover networks for the L100’s the same as in the 4312c’s? I literally stumbled upon a set that were set out by the garbage. I grew up listening to the L100’s hooked up to a Marantz 2015. I still have the receiver, but the L100s didn’t survive 30 years in a wet basement. My new speakers sound good, one is much better than the other though. Caps are more than likely dried out and the knobs are super scratchy on one speaker. If the crossovers are the same, I will do the Murphy boards and eliminate the LPads.
Just add a fixed lpad to the tweeter and/or mid. You are not going to find a pre-engineered, proper crossover for what you have unless you DIY..I have a 4312 se to which I added the titanium tweeter from the new l100 classics...
Anyone has a schematics of the new l100 classic speakers?..
Or suggest any alternative crossover.
Feel the treble is a bit overpowering
Thanks for the feed back and photos. They will help other owners make up their minds.Speaking of the Murphy crossover. I did it and am very pleased.
Here are some build pics…
4311 rather than l100.
External crossover.
The three resistors in the mid-range circuit are there, along with several of the other components, to create a band pass filter between 950 Hz and 5 kHz. That mid-range driver loudness differs widely between those frequencies, and it had to be leveled and balanced. See the raw frequency response of the mid-range driver below. It ain't even close to being flat.
The rest of those components (see the schematic below) help shape the roll-off curves of the band pass filters so they work better with the roll-off curves of the woofer and tweeter, and help filter out the shrill sounding resonance peak at 6-7 kHz seen with the old JBL crossover. It took a lot of work to get that to be decent.
I also thought the LE5 driver was good. At least the JBL marketing buzz had led us to think that back in the 1970s. And then I saw it's unfiltered frequency response. Yes, it took the most work to correct its many flaws. Compared to the LE5, the woofer and tweeter were pretty good.First of all, thanks to you and mr. Murphy for the crossover design.
Now, thanks for the curve on the LE5, frankly i am not impressed by the frequency response, I thought this was a better driver.
Of course I understand it should have taken you guys a lot of time to correct that response into something acceptable.
I see your crossover is a bit more elaborate than Troels', you are using 3rd-order electrical slope on the mid and high. Very interesting.
