I said, "And the 130A is a deeper basket/coil area"
You said "in a deep gap."
So you support what I said 130A is a deeper basket/coil area. OK...
"The difference between the 130A(2220) and most the other 4" coil drivers is the motor. The motor has a .350" top plate/gap depth. The D130 has a .280" gap depth. the frames are identical."
Again, supports what I said 130A is a deeper basket/coil area. OK...
"The cones are identical."
Then why is a 130A cone on a D130 basket considered a "frankenwoofer?"
And I know the "clank" I heard was the cone bottoming out on bass transients.
