There is a pair of 136a on eBay right now, should I be interested for $400? Looks like they need refoamed.
Check the seller's previous auctions - he had a pair of L200's for sale but no one bid so he's apparently parting them out. Usually, the 136A is not in the L200, but looks like these are the ones out of them, judging from the pictures. I'd bet one of them was reconed as the cones are not the same colors (one is light gray, the other dark grey. Also, looks like they both had good surrounds but I'll bet that one got punctured with a screwdriver while being removed (happens to all of us, but best to remove using a power tool and careful cradling of the screw bit. Both have the correct white circular vinyl gasket on the back of the frame.
This is about the going rate for true 136A's and 2231/2235H's. I'd probably suggest sending them to Orange County Speaker for an Alnico Magnet recharge, and new surrounds for both (may as well to ensure good symmetrical performance and known date of refurbishment.
If you're lucky or a really good bargainer, you might then ask if he'd do a good deal with his slant lenses that don't appear to have been put up for sale yet. And have him throw in the bolts that mounted the woofers, they probably aren't original but will come in handy.
Oh, and don't have him ship the woofers together, no matter how well bolted they are to each other. Its too much weight and unless using custom fitted blown up polyurethane molded supports, hard to protect against damage.
Much better to have him bolt the woofer face down to a 1/4" piece of plywood 15-17 inch square and secure with bolts and nuts. The whole woofer/plywood should then be wrapped or enclosed in a thick plastic bag to prevent dust and any packing material from entering. Then use a 1-2 inch thick sheet styrofoam under the plywood, and a thick cardboard cover, then at least a 2-3 inch thick sheet styrofoam behind the magnet, and a cut piece of double wall heavy cardboard tall enough to go from back of mounting flange to the top of the magnet height wise so it contact the top cardboard & styrofoam.
There is absolutely no place here for styrofoam peanuts or other material. If there is room, sheet styrofoam can be used to support the sides. All of this should be in a cut down 17-18" square or cube
double wall shipping box, that is then copiously taped closed so there is absolutely no movement when secured. Boxes like these can be had at U-Haul.
Don't let the shipper cheap out on these materials. The above is the only way to ship these securely (much like JBL's own materials).
http://www.jblproservice.com/pdf/Discrete Sales Models/2235H.pdf
This is not cheap nor inexpensive. But it is what you will find from JBL products - you get what you pay for, both in engineering and manufacturing, and performance.
