nasinn
Hi all,
This is my first post here on Audiokarma and I am looking forward to hearing your thoughts on this.
Late last year I acquired a set of L65As in goodish working condition, the cabinets were a bit rough around the edges so I did the following to get them living room worthy (from a looks perspective!):
So that brings us to the current state and the to-dos. The previous single owner had done a pretty bodged woofer refoam (at least in my opinion, keen to hear your thoughts). It was done with a rubber piece and it has been glued on the outside of the cone in what seems to have been a hurry + there are no gaskets. The woofers work okay but this bugs me and I have been thinking about the following options:
I would really appreciate your input,
Jonas
- Filled chipped corners with wood paste and cleaned up the veneer
- The base particle board was a bit shot so tht needed a bit of sanding, filling & painting
- The grilles were dirty and had holes so I replaced those with (crazy colored) acoustic fabric. I did that with velcro strips in case I get tired of the color. We ordered 50 colored samples so that could change in the future... In the process the grill frame broke, but it was relatively easy to epoxy butt-join the split as the metal frame holds it nicely together.
- By an aftermarket refoam kit then try to cut off this rubber piece and make it look proper again - I fear damaging the cone getting off the rubber
- Buying an aftermarket recone kit and replacing the cone, maybe keeping the voice coil original, but I am really keen to hear your thoughts on this. I am looking at the 122a kits on Simply Speakers / The Speaker exchange.
Jonas
