G'day all, I have both the supplied Shure elliptical and the Jico SAS for my M97xE's. The Jico SAS stylus is a superb stylus but essentially reverses the intent of the Shure Audiophile Response Curve (a 'softened' upper treble).
I like both, but each to their own of course. The main issue with the Shure stylus is that optimum capacitance is somewhat critical in order to avoid perceived 'dull' sound. Regards, Felix aka catman.
This agrees perfectly with my assessment based on a back-to-back audition. And I was using a V15VxMR-SAS to run this comparison in the M97xE body.catman said:The Jico SAS stylus is a superb stylus [which] essentially reverses the intent of the Shure Audiophile Response Curve (a 'softened' upper treble).
Speedle puts his finger on a perennial problem. Is this cartridge bright or is it bass-lite? It's very easy to be fooled by this; ask me how I know.speedle said:The SAS on my V15 Type IV added some brightness. ... Or maybe it thinned out the bottom, I'm not really sure.
As much as I enjoy my SAS styli, seminole54 makes an important point: the N97xE stylus is technically very capable; it tracks difficult material without drama at 1 gram and supplies damping to tonearms that don't have it. As always, none of this says that you have to like it, or that you're going to. But the SAS will be brighter, so if you like the sound of the 97xE as-is, there's a chance you might not like the SAS.seminole54 said:...If you like the sound of the M97xe and can get it loaded correctly then there is no reason to spend in excess of $100 on an aftermarket stylus.
An added benefit is since the diamond is so much smaller it seems to sit down in the grooves giving a great reduction in surface noise. My original copy of Let It Bleed is scary looking when you pull it out of the sleeve and scarier when touched by the ellipse. Drop the SAS on it though and a high percentage of noise is gone making that record a joy to hear.
Set up is rewarded as well. in my system I could not get IGD dialed out of it. With the SAS I very very rarely hear just a smidge of it. I assume this is the small diamond as well but stopped trying to figure it out long ago and just listen to the the music.
Does every single DIY with those RS180's have to be bright?I digress though.
I might be buying a Shure V15 Type V and I was looking at the JICO SAS stylus for it. It says that it's also good with Microgroove Lps. Anybody care to comment on this?
So far I've found the SAS on my V-15 III and II make all my albums sound great. From Dynaflex to 200g pressings![]()
Actually it's all about voicing within the crossover. I didn't design them I just built them. Jay Kim designed the x-over with optional voicing options. Those RS180s = low low low distortion drivers.
