Just rescued a Forsell Air Reference Turntable
Funny you should say that. I did in fact see a similar controller on the Lenco forums website. It was part of of a DIY project. Must be a coincidence the writing on the PC board is in French. I would think thats what they speak where the Forsell is made.
Nope we speak swedish here where the Forsell was made =).
Good luck with your project.
Made some nice progress. I was able to re-terminate the phone cartridge leads to a satisfactory level. Im sure it would have been difficult to locate a tonearm cable as light and flexible as the original. Perhaps Ill use some varnish to tame the wild hairs on the orange lead. IMG_0426.jpg
oh, and I was able to get the platter spinning freely again. There must have been some crud from the polishing process stuck between the glass and platter. I was able to lift the platter (no small feat by the way as it weighs a ton) and clean underneath. It now spins for what seems to be an eternity.
I really hope You in time get everything working properly. I believe this TT is almost a definition of a high-end TT, and still are very sought after here, and very expensive.
This has been a fun thread. I can imagine the excitement of your barn basement find!
Must've been something like this:
Here's a picture of some of the peripherals. Second pump and storage tanks on the left. Power supply and voltage converter on the right. Also got the belt today so I was able to run the platter. Motor was a it noisy at first probably from sitting around too long but after running a while it quieted down. Gonna have to measure the RPms to see if this motor will do. image.jpeg
image.jpeg Here a view of the back where the tonearm cables go. I'm gonna have to look and see what the proper wire path is into the back of the plate. I see there is a small hole on the side plate but I would have to de solder and retread it which makes be think it's not the right path. Perhaps that hole was for some sort of standoff or post that held the wire up high and out of the way.
Strangely the tt came with two pumps. One is 220v and has both input and output ports. The other is 110v and only has an output. I suspect one was for the platter and the other for the tonearm but how did the previous owner control the power? The second switch on the turntable base controls one pump, in this case the 220V version. How did the owner control power to the 110V pump? It doesn't even have a switch on it. Was the tt designed to run on one pump or two?
Generally tables like this are built into the space, meaning all the equipment isn't just stacked under the table on the rack. Most cases all the air pump equipment would be outside of the room and all wired in and air lines routed to the listening room.
Walker Proscenium Black Diamond III part 1.mp4
I thought the vids above got into the install of pumps and power, and I can't find the vid I wanted you to see.
Thanks for the videos. Anything featuring an air powered TT is helpful in the restoration process. I see the motor they use struggles initially to get up to speed and must be helped a bit manually. Mine seems to have enough power but the belt chatters a bit at startup as it tries to move the super heavy platter.
Love your avatar, I used to have a German shorthair that looked up at me like that, so cute...
Yep a big heavy platter like that needs help to get it going.
VPI recommends a dusting of talc on their belts, this may help with the startup chatter. Some controllers have a ramping startup to avoid this.
