I checked the both integrated circuits 501 and 502 and the results were interesting. I had to do it with an analog multi meter as I don't have a digital one, but I believe my analog one is accurate.
As you can see in this picture, the circled solder joints are the ICs connections to the board.
The ICs are Flipped around so these collor coded arrows show the voltages that are supposed to be the same.
having the black prongs connected to ground and red ones testing the voltages
The solder joints connected by the black line both measured: 24.9 volts
The solder joints connected by the red line both measured: 21.9 volts
The solder joints connected by the blue line both measured: about .6 volts
The solder joints connected by the grey line both measured: 21.1 volts
The solder joints connected by the yellow line both measured: 21.2 volts
The solder joints connected by a brown line both measured: 24 volts
The solder joints connected by the green line both measured: 24.1 volts
Once again these measurements were taken with an analog multimeter so they may not be 100% accurate, but they should be close.
Also I do NOT know exactly what solder joint correlates to the PIN number. not sure how to find that out. It seems weird that almost all of the voltages on the diagram would expect negative voltages and I got all positive. Also only 3 of the voltages in the schematic are supposed to measure over 20 volts and for me all except for one measured over 20 volts, though the voltages were the same for both ICs.
