I'll take a few pics in the morning, I got a lot done with it today.
The deck I have looks identical to the ones here but the number on the sticker says model SRP 93 CL. It has a 0.9uf cap (measured at 0.82uf, reasonable esr, so I left it in place). The pulley set up is interesting. The deck can be set up for 230v or 110v operation, with a transformer to step it down to 100v. The motor is synchronous, so it will run at either 50hz or 60hz. The pulley is spring loaded, with 4 steps, you just mount it higher or lower on the shaft for 50 or 60hz operation. Very clever I have to say.
The bearing isn't just the best one ever, seems to be oilite type as far as I can see with a ball at the bottom of the well. Many of the pivot points were gummy in mine, so I pretty much disassembled every one, cleaned and regreased all of them. They should last many years with modern greases.
I gave the idlers a good clean, they are both supple and feel in good condition. Table runs very freely now.
The arm was a **** show. The pivot points had worked loose and whatever bearing cups were meant to be in there were long gone. I made some new ones from brass, it "feels" ok. On some testing, the grounds were wired together at the headshell mount. I ended up rewiring the arm completely with some copper litz. I replaced the old RCA leads with new ones, and the same with the power cord. I just need to arrange the grounds now and all should be good.
Last up I gave it all a good clean, the chassis is drying off overnight. I'll give it a coat of wax tomorrow and that should protect it. The chassis is only ok on this one, there are a few nicks in it.
Hopefully I'll do a final assembly tomorrow and I'll post the pics.
