bobrown14
So the difference in a new high quality cable and jacks to the Denon´s 40 years old cable has nothing to do with this increase in quality of sound?
Newer cable most probably has lower capacitance than the original (only reason to swap out for better sound). Depending on the preamp and cart combo, using a lower capacitance cable will affect the cartridge resonant frequency. Also high capacitance cables (stock) will with some carts cause the high frequency roll off to occur in the audio band (bad; loss of clarity, muffled you get the idea). Too low cable capacitance will make the sound too brite and distorted with noticiable lack of bass.
What you really want is a flat frequency response up to say 18-20K with a steep rolloff after that. Getting there... well that's the challenge.
With all the decent carts out there and some souding much different than others of similar quality; I really think it's a matter of mismatched components. This can be fixed without changing to another expensive cart. The changes IMHO should be made at the preamp cable end of things. (Not talking high priced cables here just low capacitance). Getting the connections and the specs of the preamp to match that of the cart is where its at.
The issue really is that cart manufacturs dont always give you ALL the technical specs, so getting the setup right for your particular rig can be a crap shoot. To get the setup right you really need to know the specs of the cart AND the specs of your preamp phono input and match accordingly.
I'm not an expert on this. Just someone that is interested enough to build my own phono preamp and mess with the TT cables etc to get the best out of my VAST LP collection. Cost of the LPs by FAR exceeds any investment in carts expensive or other wise. So the goal is to get the best sound, swapping carts without all the known specs is really guessing ....
Cheers,
Bob
