KA-7100 Issue - Need Opinions
Maicobmw
Well-Known Member
I have a Kenwood KA-7100 that has a dead left channel in stereo mode, but when switched to mono both channels work. Does this sound like a potentially serious condition or perhaps a simple deoxit fix?
The good news is that it's not in the power amp section. When set to mono, the output of the L & R preamp outputs is combined, and the same signal fed to both amp channels. As you get sound out of both speakers, that tells you both amp channels are fine.
As it's in the pre-amp, of course the absolute first thing you need to do is clean all of the controls. There are several thousand posts in this forum detailing exactly what to do and how to do it using DeOxit contact cleaner. Have you tried operating all of the controls (especially things like Tape Monitor switches and filter switches that rarely get used) to see if you can make any noise at all in the left channel? Once you've got all the switches and pots cleaned we can re-evaluate.
Ok, that makes me feel a little better than thinking it was a complete doomsday situation.
I get nothing at all out of the left channel rather than an intermittent issue, which is what worries me in particular, but yeah a good cleaning first for sure.
Thanks
Intermittent is good, although intermittent faults can be a bitch to trace down. It means that it's probably either an oxidation (cleaning) issue or a bad solder joint. It could be other things, but there's a 95%+ chance it's the abovementioned items.
