Some great comments Philip...I agree with many of the things that you say.
In case somebody comes to this thread before they begin their build I would like to offer my thoughts after completing my amplifier:
Summary:
I would do it again in a heartbeat ...I learned so much, and feel a huge sense of achievement having built the amplifier that I now listen to as my "daily".
FYI I followed Mark's series (almost) religously ...Hammond chassis; component placement; wiring schema; etc.
Things that I would definitely do the same again:
Watch Mark's videos thoroughly before starting, and then refer to them frequently during the build
Watch Stephe's (Skunkie's) videos
Take my time with the construction
Buy a stepper drill bit (great invention)
Buy hole punches (although I didn't splurge on expensive ones so they may not last me for many more builds)
Buy Edcor OPTs and choke
Install a Thermistor
Use a Blue LED / mains switch
"Float" the 6.3v heater wiring with a virtual center tap ground
Buy/use an isolation transformer / Variac (I did buy a Variac that is also an isolation transformer although I know that most of them are not)
Buy a big box of different sized heat shrink
Build Rob Robinette's bucking transformer:
https://robrobinette.com/5e3_Modifications.htm#Bucking_Transformer ...although I am finding that the lower voltage from the Hammond PT (compared with the Edcor PT) is negating its use/need
Things that I would do differently:
Use solid wire for the wiring inside the amp (in a newbie's hands, stranded does not create a neat look)
Buy a Hammond PT from the onset ...the buzz I got from the original Edcor PT drove me cuckoo
Find a better way to measure /drill the tube sockets and their mounting screws ...I always found myself having to make "adjustments" with my Dremel. There must be a better technique ..???
Develop the technique for soldering coax to high-quality RCAs ...that was more difficult than most of the other soldering
Place the cathode resistors on the outside (top) of the chassis (a la Skunkie) ...keeps the heat out and gives easy access for measuring voltage (and subsequently cathode current)
Buy a deburring tool (sooner)
I hope that this is helpful for anybody thinking of building this amp.
In the words of the great guru, Nike ... Just Do It!!
Dave
