This is my Accuphase yourney so far
Last year I made my first step towars Accuphase with a nice C-222 I bought in Germany. It sounded fantastic and I gave it a full restoration. Then the itch started for a Accuphase power amp. When the C-222 sounds so good, how will it sound with an Accuphase power amp and how will it compare to my Yamaha B-2 and my Sony TA-N7B power amps?
So I took a dive into the specs of all power amps from the early to mid 80's. The P-266 is the official partner of the C-222, but it has a MOS-FET end stage and I really wanted a BJT end stage. So I settled on a P-300L and I 'won' a fine specimen on Yahoo Japan. I also won a A-8 wood enclosure for the P-300L and asked Buyee (proxy website for buying through Yahoo Japan) to merge them together and to pack it very well. I had very good experience with Buyee in the past and they always used some kind of memory foam around amps and other gear.
But this time they did a horrible job. They placed the 30kg weighing P-300L + A-8 wooden cabinet in a way too large box UPSIDE DOWN and they filled the space around it with hundreds of air pockets (not kidding). The P-300L survived but the A-8 - which are very rare to find separately - was completely trashed
I will never ever use Buyee again, their service degraded drastically. I later found out through recent online reviews that I was not the only one.
How it arrived:
View attachment 3195953View attachment 3195955View attachment 3195956
It was working fine and it sounded great. But it was completely untouched and all parts were already 40 years old, so I decided to restore the amplifier boards. I replaced all electrolytics, diodes (except the light emitting LT-8001P's), zeners, fusible resistors, the bias trimmer pot and the DC servo op-amp with a DIP-socket. I also went from old dried out thermal paste and mica sheets to Bergquist K10 kapton sil-pads for the power transistors. I also re-soldered all joints. Man, what a breeze it is to work on these neat high quality PCB's. The best I ever experienced.
But then I realized that the 'real' companion for the P-300L is actually the C-200L pre-amp. They can be connected to each other with a balanced XLR cable. And the C-222 did not have a balanced output. And looking at the schematics, the C-200L seemed to be a serious upgrade from the C-222. That's when the 'always want to upgrade-itch' started to happen again
It made me sell the C-222 to a very nice Accuphase-lover in Germany and he was very happy with it. I started to look for a fine C-200L in Japan and a month ago I found one.
This time I bought it through proxy website FromJapan and they did an excellent job in packing the pre-amp. It arrived very quickly safe in the Netherlands.
I cleaned the C-200L, because it was very dusty. Also this unit was completely untouched and in a near mint condition. The sound in one channel cutted out regularly and it turned out to be caused by the Stereo/Rev stereo/mono switch which unfortunately is a well known open Alps rotary switch which was completely oxidized. For some strange reason they used relays everywhere for signal switching, but the signal is going through this Alps switch.
I took the switch apart and restored it and now it's not causing problems anymore. Maybe I will bypass it in the future, because who needs this function anyway?
The only problem left is that the sound output on the right channel is lesser than the left channel. I have to put the balance pot on 3 o'clock to get an equal volume from both channels. I will restore this unit in the near future and then I will investigate this problem. But that can be a pretty hard process because the schematics and / or service manual for the C-200L are non-existent unfortunately...
Cheers,
Oscar
