GRRRR, for my part! I wish I had seen this before. I've been looking for another pair for bi-amping. And the third parts unit would not have been bad either.
I can say with all confidence that you will enjoy these amps, meggy. It should say something indeed that I gladly traded some Mac gear for mine, and have not looked back once. Their reputation for fine sound and reliability is well deserved. Pair them up with a good preamp and you will not be disappointed.
To get the most out of them, place them as close to your speakers as you can and use a short length of medium-heavy (14-12 ga) speaker cable, and longer lengths of high-quality, well shielded patch cable between the amps and the preamp. They were designed to be run with a special 14-wire cable (Kenwood’s Sigma cable) and each run was meant to be less than a meter (or yard) in length. I have the special cable, and each run is ~14-inches ; its about as close as you can get to having no speaker cable at all.
On the matter of L-07M mkI vs. mkII, I think that if one were to measure the mkI model with the same +/-3dB parameters as the mkII version, they would spec out the same (or much closer to it; the mkI's are very conservatively rated). Suffice it to say that either version has a frequency response that extends well beyond anyone’s ability to hear.
Aaron: One of these times I get down to the Cities, I’ll bring them along; maybe try bi-amping Ron’s Altec/Fostex/EV setup with your L-09M’s. They will make an appearance at the little Mid-west AK-Fest, in any event. I’m still divided on what pre to bring though: the Mitsubishi DA-P10 or the SAE mkIB… Choices.
