kvflyer
I don't doubt that you found values of the resistors high. Gosh, some equipment that I work on are 300% high. So far, I am concentrating on the paper and low value electrolytic capacitors. The FM is working but still has some capacitors that I have not checked. Even if they test good, I will probably change them since I will already have one end lifted for testing.
I might mention that even though it is proper to snip a lead and "J-Hook" the new component to the old lead (so as to not disturb tube socket lugs etc.), I strive to remove all of the old leads and install the new component the same way that the original builders did. It is just pride on my part, or maybe a challenge!
Bucking transformer is a good idea. My mains here is usually 121-122 VAC. Right now, it is being powered by a Sencore PR57 and kept at 117 VAC for testing.
Pictures later.
Pictures later.
