petehall347
the brandy coffee man
now put your meter right across de17 .
should see 28.5v dc .
its a zener diode that steadies the voltage to 28.5v .to supply qe31 base so qe31 emits 28v thats missing at pin 8 .
if the voltage is present across de17 . qe31 is bad or it has poor soldering on its legs . or the board is cracked .
if voltage not present re75 is bad and or de17 is bad .
Not to butt in... but last I had this issue with my 9100, the mode selector switches were in the improper position... also make sure (if this model is designed as such), the amp/preamp switch is not set to "separate".
