I haven't thought about amp projects or electronics for a while. Regular diodes are tested the same way as in the link pete gave you for testing transistors.
But I just remembered and/or I believe that LEDs have different dropping voltage(s) than the approximate .7v that is typical of a regular diode or between two legs of a transistor. So I do not know whether an LED can be tested the same way as a regular diode. But petehall and (likely) most others reading this thread would know.
The first two main places that many people here buy parts online are Digi-Key and Mouser. Both excellent sources with great customer service and a wide range of parts.
