Squidward said:There are no pre-out/main-in jacks. It's an "integrated amp" in the strictest sense of the phrase! So no, I can't test to see which section is wonky.
hpsenicka said:Interesting suggestion.... might be worth a try, but the symptoms still suggest there is a problem with the power amp section in any case.
mhardy6647 said:Try a phono cartridge IN and see if you get preamplified, equalized signal OUT of the tape outputs. That should tell you if the low-level (preamp) part of the amp is doing anything at all.
Did you check the fuses? They're all inside the 7100, as I recall, but still worth checking. No relay click's a bad sign, though.
SPL db said:That's what I told you to do as well...
Scott :thmbsp:
