EchoWars said:hpsenicka, L channel blown.
Squidward, transistor is in wrong.
Too funny...
I don't know why, but every single 7100 I've ever worked on needed a new relay driver transistor. Every bloody one...(OK, there might have been one that was OK, but I've worked on a dozen or more of the things and probably 11 of 'em needed a new driver tranny).
The suspect transistor is Qe34, and is at the very front of the horizontally mounted 'motherboard' of the unit, just about dead-center. I believe that the component designations are silkscreened into the board, so you should have no problem locating it. Immediately next to it is a ground terminal with a couple of black wires on it.
The view here is from the conductor (foil) side of the board.
If there is about .6 ~ .7V on the base of the transistor, and 25 to 30-something volts on the collector, then the transistor is bad.
Even a cheapie RatShack 2N3904 will work fine for a replacement, but the pinout of these RatShack transistors cannot be taken for granted...you must determine for yourself which lead is base, collector, and emitter.
Looks like the one...This pic labelled C1213 is the Q34 position piece in my KA-7100... correct one for relay?
No...just because you can get three leads into three holes doesn't mean they are in the right place.It seems that with the three pins, this could only be installed correctly, or 180 deg opposite. Am I thinking right on this?
Looks like the one...No...just because you can get three leads into three holes doesn't mean they are in the right place.
The connections on that transistor are (from rear to front): Base, Collector, Emitter. Not all transistors are laid out that way. While most Japanese transistors have the collector as the center lead (and the base sometimes on the left, and sometimes on the right), many European and North American transistors have the base in the center. I frequently use Zetex ZTX1056A transistors for relay drivers, and they have a CBE layout. They just don't get installed as neatly as the original.
Just wanted to send all of you guys out a thanks for this old thread. I bought a KA-7100 at a swap meet for $30 and was sadly disapointed that it did not work when I brought it home.
Checked the voltages at Q34 transister, tested bad and replaced with the .79 cent radioshack part. Amp fired right up, relay clicked and it sounds great!
Thanks again guys!
