Squidward said:Sorry - my other problem is that I'm pretty dense!
gearhead said:
EchoWars said:If there is about .6 ~ .7V on the base of the transistor, and 25 to 30-something volts on the collector, then the transistor is bad.
Even a cheapie RatShack 2N3904 will work fine for a replacement, but the pinout of these RatShack transistors cannot be taken for granted...you must determine for yourself which lead is base, collector, and emitter.
http://www.radioshack.com/product.a...name=CTLG_011_002_017_000&product_id=276-2016
Jim H B said:Squidward, sorry to ask so many questions, but I'd like to learn some of this myself.
How did you make the tests on the transistor? Did you desolder it and remove it from the PCB first?
If you didn't remove it, did you have the power on when testing?
What instrument did you use to test it? If it was a multimeter, where did you put the red and black leads, and what setting did you use?
Use small words, you know how us State fans are...
Jim
