KG4 passive cracks
BobDoh
Found a pair of KG4's but noticed in one picture some cracks around the passive. Is this something that needs to be repaired?
Probably fine. You can put a thin layer of Aleenes craft glue on the outer surround if you're concerned. As long as everything is air tight, you're good.
Those cracks are very common on KG4, as long as the cracks are on the outside & not on a moving part of the surround or where it can leak air they are fine.
If you want to fill the cracks i would suggest a silicone type caulk or even better an automotive RTV type gasket sealer/maker, permatex ultra black is a flexible RTV that will fill the cracks & match the black & function much better than a standard white craft glue mentioned above.
