Looking good, you will be proud of these when they're done!
Dumb question, because mine are the first pair of cloth surround speakers I've ever owned... I applied a light coat of the surround dope that I got from Roy C I think Wednesday evening. The speakers definitely needed it because I had one of the drivers out for a recap when I did, and shining a dim flashlight from behind through the surround revealed exactly what I suspected, that they were essentially completely dry. They may even need another super light coat; I can tell from the one driver that is out that in some places the new dope went right through the cloth (because I could feel the tackiness on the backside of the surround.) The question is, it's Saturday morning and they're still a little tacky. I guess I just assumed that it would dry to the touch in a day or so. Is this normal and I should just proceed on and reattach the grilles? OK to go ahead and listen to them? As of right now the only things needed to call these "done" are one cap, Deoxiting the selector switches (not sure if it's needed, but when am I going to have the opportunity again?) and gluing the Velcro for the grilles back onto the backs of the grilles, but I don't want to push it if playing the speakers before the surrounds are in shape is bad for some reason.
Also, I see there's wire nuts in the driver wires. Do you think it's worthwhile to redo those connections with solder, or is this generally not a big deal?
