@moray james. I’d like to know your thinking about the tweeter the mid-range horns, and cross-overs.
The obvious range of options is pretty clear at the less effort scale:
- Do nothing and enjoy
- Do the maintenance steps listed above
- Install tubes on the bass ports
What’s less clear is the part where you start spending money. I suspect that’s because people have different objectives. Mine are:
- Find any fix anything that’s broken
- Preventative maintenance such as replacing oil based capacitors in Heresy Is
- Incremental upgrades, such as new technology diaphragms
- Modifications to improve from the original construction and design
- Internal bracing
- Changed components, such as drivers
The tweeter choice seems simple, as so many suggest the Crites Titanium tweeter mod.
The midrange horn seems to me the biggest enigma. Some have said leave it alone, others like Crites mods, and then there’s the more complicated switch over to Tractrix.
I may find the crossover even more enigmatic as there’s a lot less out there on Chorus I crossovers than there is on AA crossovers.
