Klipsch Heresy II
Acdcpsp
So I recently bought a pair of the Klipsch Heresy II for 350 on eBay. They are in great condition. So how did I do? Do they got great low end?
Specs:
SPECIFICATIONS
■BUILT FROM: 1985
■BUILT UNTIL: 2005
■CROSSOVER FREQUENCY: HF: 6000Hz
LF: 700Hz
■DIMENSIONS: 21.375" (54.29cm) x 15.5" (39.37cm) x 13.25" (33.66cm)
■ENCLOSURE MATERIAL: MDF
■ENCLOSURE TYPE: Sealed
■FINISHES: Walnut lacquer, Mahogany Lacquer, Medium Oak lacquer, Unfinished Oak, Black Lacquer
■FREQUENCY RESPONSE: 63Hz-20kHz(+-)3dB
■MAX ACOUSTIC OUTPUT: 114dB SPL
■MAXIMUM ACOUSTIC OUTPUT: 114dB SPL
■MID FREQUENCY HORN: Exponential Horn
■MIDRANGE: K-53-K 1.75" (3.81cm) Phenolic diaphragm compression driver
■NOMINAL IMPEDANCE: 8 ohms
■POWER HANDLING: 100 w max continuous (400 w peak)
■SENSITIVITY: 97dB @ 1watt/1meter
■TWEETER: K-76-K 1" (2.54cm) Polyetherimide diaphragm compression driver
■WEIGHT: 37 lbs. (16.8kg)
■WOOFER: K-24-K 12" (30.48cm) Fiber-composite cone
The Heresey is called that for a reason!
Really.
They can sound good if powered right in my experience. Although they are able to be driven with low power they really start to come into their own with big power and the best system you ca afford in front of them.
Building a system from scratch around Hereseys takes some choices which help maximize the positives and minimize the negatives which while true of all speakers may be more so with these Klipsch.
Anyway congrats they are a classic and I know you will like them in the log run.
Ed
This is a whole new kettle of fish...
But if you ever re-cap the XOs many here would recommend Crites. If you do go that route then you could adjust this cap to 'tune' your Klipsch (see pic) YMMV
:thmbsp:
Yes, the Heresy's do roll off at around 60hz, but.....
The bass down to that point is very clean and articulate, imo. I used to have a pair I bought new (at Accomodation price) which sounded great in a moderate size room driven by an NAD 7140 receiver. It's bass SQ, which attenuates the bottom octave, was still one of its best aspects to my ears. With another strong positive being its dynamics.
I got my HII new back then and I took a AKers advice a few months ago and rasied them up on stands (bedroom fronts now)so the mid horns are at ear level and added a sub...WOW:music:. Not as full as my Cornwalls but a BIG difference :thmbsp: should have done this 10 years ago.Both of my Klipsch are keepers. I NEVER see nice Heresy II for $200.00 in the DFW area. $350.00 to $400.00 for a nice looking pair is the going price aould here. You did Good.:thmbsp: add a sub :yes: I purchased new cross overs from Bob Crites for my Cornwalls last year :D and soon I will do the same with my Heresy II. The networks fall out of spec so slowely after 20 years you don't notice it so much until they are fresh again. As far as Cerwin Vegas go, my son has a pair of AT-15 I purchased for him in 1989 and the Red foam surrounds are cracked and split now and need to be repaired. I purchased my Corns new in 79 and the 15" woofer still sound and look new(not foam). All have been in a A/C home. Yes the big CV AT-15" have more bass but the mids are flatt vs the Heresy.I am not knocking the CV(great R&R speakers) just posting what ours have done and how they sound to me. IMHO everyone likes something different and hears a little different. Enjoy and welcome to the Heritage Club.:music:
Really.
Ed
I'm going to be powering these Speakers with a 300 watt aoudiosource amp 3. 150 into 8 ohms so I think i'll be okay there. I'm using a H/k 3380 has a pre.
$350 appears to be the going rate for all original.
Heresys are excellent speakers, I did a listen in the store vs K-horns, Belles, LaScalas and bought the heresys. Just turn the bass up a bit and you approach the larger relatives.
As stated above, if you want sub woofer sound, add a sub.
I have two pairs that I probably will never sell, I also purchased the LaScalas a couple of years after the Heresys late 80s. The K Horns and Belles were just too big and hard to move for me and my gypsy life style at the time.
IMHO you did well, and as stated above if you want to upgrade the crossovers, Crites has a very good reputation. I have dealt with him satisfactorily.
Heresy can impress...
I plan on doing a crossover upgrade.
If you want to get the most out of your Heresy there are a few things that you can do to stack the odds in your favor. I have a pair of 82 Heresy and a pair or H3. Take a look at how a Heresy can be retro braced in the following link. This provides maximum stiffness with minimum volume loss.
http://www.audiokarma.org/forums/showthread.php?t=438234&highlight=heresy+brace+work
If you brace and seal the cabinets and damp them with one of the 700 series Dow Corning fiberglass materials you will get the most possible out of the cabinet. Damp the volume. There are a number of other tweaks which can also help with bass and mid bass response of the cabinet. While the Heresy starts it's roll off early it is a sealed box and rolls slowly so it still does very well at lower frequencies all things considered. I have a pair of HSU subs and there are many times I find myself marveling at the quality of the bass the system is making and then look to see that the subs are off.. Finding an amp which can actually make bass is another good plan because most can't and don't and when you find one that will a Heresy will not fail to impress you. No it will never do seismic but it can do a stand up job without a sub and a stunning job with the addition of a quality pair of subs.
Damping the woofer spider with three layers of 1/8" SAE rated F-11 acoustical and also damping the woofer struts will also provide additional bass quality as will a layer of Dynamat on the back side of the woofer magnet. Most never go to the trouble but as I said the Heresy can impress at a very high level of performance if you do a little work and help it to do its job. Large gage air core inductors are your best investment for a crossover upgrade if you want bass and dynamics followed by some top quality capacitors. Have fun. Best regards Moray James.
I don't think I want to go to all that trouble. I'd rather port the cabinet that right there will allow the bass to be much deeper. IMO
Port a Heresy? That is heresy!
I think Klipsch made a Heresy that was ported for Pro use??? I would never cut on my HII either as I like they way it sounds now that I have added a sub(Cornwalls spoiled me) and raised them up so the mids are at ear level like my Cornwalls are.I have owned them both from day one :yes: mine are keepers just the way they are. I have Crites networks in my Corns and might try his CT125 tweeters some day.
It might and it might not....
you might get a few db more output (porting) over a half octave or so but you have to remember that once you hit the tuned frequency with a vented design the response then drops like a rock below that frequency. That's one of the things which makes a sealed design so nice because it just slowly smoothly rolls off. A smooth roll of also sound much more natural than a fast drop does. I plan on removing the passives from my Forte ll and sealing the cabinet to see how it sounds. Will try the same with my KLF20. Ported or sealed you will find that a solid well braced box is your best friend. It's all in the details and there is no short cut or easy way around it. If you do a little at a time it should convince you that the results justify the effort. Best of luck with your Heresy ll. Best regards Moray James.
