Kegger
R.I.P. 1/12/1966 - 6/1/2017
I see lots of threads in the guitar world about the sound and tonal quality differnces between say 6v6 or EL84 and EL34 or 6L6. I don't see as much from the Hi-Fi threads, wondering if the tonal differences are not as distinctive here?
So in a SE UL configuration like this with EL34, 6L6GC, KT88 or whatever... is there a distinctive difference in the sound compared to say an EL84 or is it primarily just for more power? If blindfolded and the amp set to put out the exact same dB level can you identify which tube you are hearing? If so by what quality?
I would say for the most part yes, there is a pretty "distinctive" difference between say an EL34 and a KT88.
The KT77 is another that differs an fair amount to be heard, even more so in single ended circuits, along with
the drivers, even more I'd say with the drivers, quite often even the rectifiers still in single ended amps as well.
So yah with this particular amp where you can roll many drivers, outputs, an even rectifiers you can tailor a lot.
We are having rolling blackouts here and I've got limited time online, so my responses are slow for a bit here now.
