captainclock
Pacifist Otaku
Hello Everyone, the other day I was asked to see if I could get a late 1960s vintage Fender Deluxe Reverb up and running for a friend of mine who's son had gotten it from his school who was about to throw it out because it wasn't working. Anyways it doesn't want to put out any audio when its turned on and the standby switch is switched on (which is supposed to turn on the B+ to the amp from what I read online about it.) I had already tested the B+ on the 6V6s and they tested mostly within specs and the 12AT7s tested mostly within specs and so did the 12AX7, the 7025s however tested at only -0.625 Volts which I'm guessing is where the fault lies.
Anyone on here ever work on this particular amp before and specifically work on an amp with this particular problem before?
Any help would be welcome.
Thanks,
Levi
Thanks,
Levi
