Yes, they are a pain in the ***. DAMN YOU THORENS ENGINEERS, DAMN YOU!! Lencos are easy to work on. Garrards are easy to work on. Technics-es are generally easy to work on... But THORENS... the least manteinance-friendly turntables there are.
Pressed-in bearing ? Yuck
Pressed-in bearing spindle (pressed into the inner platter)? Yuck
Stroboscope glued inside the inner platter (instead of machined into it as any other serious manufacturer would do)? Yuck
Able to take out the top plate without having to put the turntable upside down (and draining the bearings as a consequence). NO! !"/#&!"#/!"#
But i recognize there's no reason the deck couldn't be modified into a
perfect vinyl spinner.
Yes, i do have the FD200 damper
Now i need silicone fluid, but i guess i can use motor oil "stop leak" additive. It is highly viscous.
