Looks like you may have to get a line-voltage step-up transformer, or get a plug to fit your electric dryer outlet (ha ha). It doesn't look like you can set it for 120v.
I dont think I could gut a clean Leak preamp to make it a passive. Even if I didn't want to run it, it would have to stay intact, but then again I can't bring myself to tear apart anything that isn't completely trashed. Even then, I often find it more of a challenge to put Humpty Dumpty back together again.
I can't help with cables, but I have the Sams folder scanned for the Stereo 20 and might have the Point One Stereo as well. tbavis(at)rochester(dot)rr(dot)com
The preamp will only work with a cable connected to the power amp unless it's already modified and you have an external power supply. Do you have the octal cable that connects the two?
To be brutally honest, there really isn't much you can do to a Point One Stereo to make it sound more than "OK" without a major gutting.
Yes....99.9% of what I've read about the Point One preamp is not too flattering (and I'm being kind...but I have some time to decide what I'm gonna do with it:scratch2:
I've also read that it would be best to use a passive pre with the ST20 which is why I'm thinking about gutting the preamp......decisions, decisions
Thank you all for your responses:thmbsp: and keep them coming![]()
Why gut the preamp?just sell it to a collector and buy a seperate passive preamp?
A passive isn't always the best option due to the limitations it has. If you can get it close enough to the amp a passive works very well though. I used one for a while 'till amp placement became an issue with the monoblocks.
There are some preamps with variable output, for example I use a Rega Cursa, which can output three different voltages. I use it at unity gain (it's actually a bit more then unity), and it can drive longer cables, which is where a passive can have issues if the cable capacitance is too high. Croft preamps can also be ordered with low output specifically for matching to high sensitivity amps like the Leaks.
I use mine with Tannoys - a very good match.
