Preamp Stage Restoration/Upgrade
Signal Path Capacitors:
The stock capacitors in the input high-pass filter (CE01, CE02) were 0.47µF low leakage electrolytic capacitors and these were replaced with 0.47µF Panasonic stacked polyester film capacitors. The F3 of this high-pass filter is 0.34Hz. Note that one could use a smaller value(0.22µF or even 0.1µF) higher quality polypropylene capacitor as a replacement, if desired.
The stock phase compensation capacitors, CE03 and CE04, in the local negative feedback loop were ordinary 68pF ceramic capacitors. These were replaced with C0G/NPO capacitors of the same value.
Similarly, the stock capacitors (CE17, CE18) in the Miller feedback loop were also ordinary 100pF ceramic capacitors and were replaced with C0G/NPO capacitors of the same value.
The output capacitors of the first preamp gain stage, CE05 and CE06, were 4.7µF/25V low leakage electrolytics and these were replaced with 4.7µF/50V Nichicon FW Audio Grade electrolytic capacitors.
The stock capacitors in the input high-pass filter (CE07, CE08) of the second preamp stage (following the tone controls) were 0.47µF low leakage electrolytic capacitors and these were replaced with 0.47µF Panasonic stacked polyester film capacitors.
The output capacitors of the 2nd preamp stage, CE11 and CE12, were 4.7µF/25V low leakage electrolytics and these were replaced with 4.7µF/50V Nichicon FW Audio Grade electrolytic capacitors.
Non-signal Path Capacitors:
The local DC filtering capacitor for the preamp stage, CE19, was a 10µF/50V electrolytic and was replaced with a 100µF/50V Sanyo CA 105°C low ESR type.
The filtering capacitors CE15, CE16 were 10µF/50V electrolytics and were replaced with 22µF/50V Panasonic FR low ESR types.
The stock bypass capacitors CE09, CE10 were 100µF/10V electrolytics and these were replaced with 100µF/25V Panasonic FR low ESR types.
