Leestereo
The "dual diodes" appear to be DS-133 (common cathode). If so, how about something like the On Semi MUR1620? (TO220 package)?
The 1090 dual diode is DS-133A and is not common cathode, but with a cathode to anode middle pin.
So, I'm curious what characteristics caused you to choose the polystyrene over polypropylene? I thought the ECW series was de rigeur? Perhaps it's capacitance availability?
Polystyrene film capacitors are considered to be closer to the ideal capacitor than polypropylene types. I think that only teflon capacitors garner more praise. Many of the higher end Marantz models used polystyrene capacitors in the RIAA equalization (appear as silver colored foil encased in plastic tube). But polystyrene capacitors are harder to find, largest value is about 10nF and are susceptible to heat damage during installation (solder with a heat sink attached to the lead).
...I find it interesting that other than the Xicon, none of the others have a brand name, does anyone know why this is? And are these all NOS?
Leestereo, you mention about the polystyrene being very sensitive to heat and when soldering these into the PCB you should use a heat sink. Can you explain what and how you would use a heat sink? As I would imagine that you would have the capacitor mounted off the board with sleeving over the wire leads, so the only other place to connect a heat sink would be on the leads on the side being soldered, would this be sufficient?...
. . . The open frame trimmer resistors (R771 and R772) used for setting the bias current were replaced with 500ohm mutlti-turn types. . . .
Where did you get these? Do you have a Mouser / Digikey part number?
I'm curious why you replaced C733/C734 with bipolar electrolytics if the original were polarized.
Sound Impressions of Restoration/Upgrade
The 1090, even in stock form, was pleasant to listen to, it does have the Marantz "house" sound: somewhat "warm" sounding with a full bass. It didn't sound as smooth as the early-to-mid 70s Marantzes that I have heard (e.g., the 2270 receiver or the capacitor-coupled 1060 integrated amp); it was more like the later 70s Marantzes (e.g., 1152DC, 170DC). I did make a note that the treble range was a bit "brash" sounding; nothing too obvious, but noticeable at higher sound levels and with recordings with lots of percussion or brass instruments.
Is it fair to assume that you didn't change the PF01 section of PCB400 because you operate without the tone controls engaged or was nothing there worth changing?
Your description on how this model sounds in its stock form is very accurate and similar to the 1090's I have had. The 1090 is not one of my favorite models due to its "later 70s Marantz(es)" sound. If you modifications helped tame the treble, then it was certainly worth the effort.
