Well, I doubt it is oscillation- 970BX is well decoupled, and in other similar model to my expirience both mentioned op amps does not oscillate. Even a LM6170 stands good at that place and it is 100MHz/2000V/uS unit.Tried LM4562 and LME49720 but there is a noise (oscillation?) through the speakers even with the volume at lowest?
I should have said makes an oscillating sound sort of a bzz bzzWell, I doubt it is oscillation- 970BX is well decoupled, and in other similar model to my expirience both mentioned op amps does not oscillate. Even a LM6170 stands good at that place and it is 100MHz/2000V/uS unit.
Something else is made noise there, check the socket, use quality one.
Having Rotel RA1070, the only tried op amp oscillating was AD828, and it is 130MHz/450V/us. At the end, left OPA2132 as standard and/or AD712, both ful, ritch sound
Sure. Either for 980/985 and 1070- the schematics is very similar to RA970.Would any of this thread be relevant to a RA-980BX ? Or has anyone tweaked one? For a start C513 / C514 are the input capacitors so 10uf film?
Spooky has a recommendation for new rectifiers with heat sinks.I just recapped an RA-840BX3 and RT830.
Those caps are definitely dead. I wouldn't power the thing up with caps that look like that. They and all the other electrolytics in the unit need to be replaced. Those caps may have taken out the rectifiers when they blew.
If it's like my 840BX3 and has a phono stage, there may be a couple tantalum caps used for interstage coupling. In my unit those caps were noisy and caused motorboating in one channel of the phono preamp. I'd replace those, too.
I had a crackling sound in the right channel, only when I used the Tone control. It was the NJM2114 that was defect after so many years. I never replace old opamps with new opamps. I replaced the NJM2114 with a NJM2068 and often by the same time-bound types. It is an older type, smaller slew rate, a little more THD and more noise. The best part is I cannot hear the difference.JRC2114D opamp ...no noises and smooth! After listening for a while I found the opa2134 bright and fatiguing, the NJM2114d is preferable.
