It's a pretty clean unit, BEFORE I cleaned it up.
It was set for 100Volts. That seemed a little odd. I moved the jumper to 120Volt setting. Not even sure why I looked under that cover but maybe my spidey-sense was tingling.
Broken plastic parts, thanks FedEx.
Broken plastic part. I'm assuming those are isolated binding posts, and I should ignore... Maybe just a cosmetic issue.
Another angle. The bend is tiny, probably 1/8" or a few mm. The picture makes it look worse.
