Goodmorning everybody,
One step further..... Still figuring out why there is no sound to be heard from the left channel....
So far I figured out the following:
1. The TR701-TR704 Resistors on the Tone Control Board were placed wrong - Replaced them with new ones (KSC1845 with approx. ~385 hFE, all of them, could not find ones with ~450).
2. There is sound from the left channel, but almost not hearable (even on 100% volume). Checked it with headphones, the same (sound is stereo, so it is no "leakage" from the right channel).
3. If I bypass the Tone Control Board (using the Main Input on the back), the sound is equal loud on both channels. So Main Amp is working properly I suppose.
The Tone Control Board was the first Board I worked on (first board EVER, soldering for the first time in my life), so there might have gone something wrong there...
How can I find out why the volume is so extremely low on the left channel? Could the problem be on the Tone Control Board?
Did I use the right replacement-parts? Does the tolerance of the Capacitors have any influence? Does a large difference Working Voltage (110V in stead of 50V) matter? Is the Brand of the Capacitors important (Mouser did not always have exactly the same at stock as LeeStereo suggested)?
Your help is so much appreciated. Know already for sure that this is going to be my new lifetime hobby; learning every day!
PART 2. Tone Control Block F-1272-1
C701-C702 Film Capacitors .47uF 100V 10% Cornell Dubilier 598-474MSR100K
C707-C708 Aluminium Electrolytic Capacitors - Radial Leaded 25volts 10uF 85c 5x11 2LS Nichicon 647-UES1E100MDM
C723-C724 Aluminium Electrolytic Capacitors - Radial Leaded 25volts 10uF 85c 5x11 2LS Nichicon 647-UES1E100MDM
C725-C726 Film Capacitors 0.33 uF 100V 10% Cornell Dubilier 598-334MMR100K
C717-C718 Film Capacitors 1uF 50 Volts 10% WIMA 505-MKS02-1/50/10
C705-C706 Aluminium Electrolytic Capacitors - Radial Leaded 6.3volts 100uF 85c 5x9 2LS Nichicon 647-URS0J101MDD
C721-C722 Aluminium Electrolytic Capacitors - Radial Leaded 10V 47uF -55 to 105C Nichicon 647-UKA1A470MDD1TD
solder side (DC filtering) Aluminium Electrolytic Capacitors - Radial Leaded 35VDC 33uF 5x11mm LS 5.0mm Panasonic 667-EEU-FR1V330B
TR701-TR704 Bipolar Transistors - BJT NPN Epitaxial Sil ON Semiconductor 512-KSC1845FTA
C709-C710 Film Capacitors 50volts 0.033uF 10% LS 5mm KEMET 80-MMK5333K50J01L4
C715-C716 Film Capacitors 50volts 0.033uF 10% LS 5mm KEMET 80-MMK5333K50J01L4
C713-C714 Film Capacitors 0.008uF 100Volts Cornell Dubilier 598-185822J100RAB-F
C711-C712 Multilayer Ceramic Capacitors MLCC - Leaded KEMET 80-C323C202KAG5TA
