kevintomb
Well-Known Member
What are those subs and mains you are using if I can ask?
OMG people that go "on and on" about using high level signals for a POWERED sub.........
Bad idea for many ways, and yet some keep trying to justify something that has no actual merit.
Doing this is simply using redundant and unnecessary amplification for no real benefit.
The idea that you are getting the "Same sound" as your main speakers, is a pointless argument, as you are not anyways. You are getting only deep bass and that has no comparison to the rest of the spectrum.
Amps DO sound so similar, that saying every amp has a certain sonic signature, ignores the fact that you are then sending it to ANOTHER sub amp on top of the first amp. So even if every amp did have some unique special sonic signature, it would be lost by compiling that signature onto another.........SMH.
Yes. It's two inputs. Left and right. BTW, it didn't remove all separation. Just some. When I removed one wire, the sound "spread" more in the mains.My guess is that your sub has only a mono sub input rather than left/right -- that's common for lower end subs and it's kind of the only thing that could explain what you heard. If your sub actually has 2 RCA's that you connected preamp left/right to, maybe one sub RCA was the mono sub input, and maybe the other was something else (like a sub output to daisy chain another sub).
Alternatively, if you used a Y-cable to connect the preamp left/right outputs to the single sub input, then you were essentially shorting the left and right preamp channels together -- so the sound from the main speakers would go to mono and have other negative impacts. That's actually not healthy for the preamp either (though it probably wouldn't have caused any damage).
Any RCA "output" can be split with a Y cable to go to multiple sources, but you cannot use a Y cable to combine multiple sources (in this case, left and right channels) into a single RCA "input".
If it was indeed stereo left/right preamp outputs connected to sub left/right RCA inputs, then the only thing I can think of that would kill bass would be if one of the RCA inputs was "out of phase" so that the left and right channel bass frequencies cancel each other out -- this is easy to mistakenly do with speaker wires if not careful with polarity, but it's almost impossible with RCA cables since the polarity is fixed internal to the device.
Let alone the fact that the "Main" amp, may actually roll off or not present a pristine signal at all really low frequencies. There if far more chance of signal loss on the low end, once amplified, as compared to a direct pre-out signal.
In reality, I doubt it is a HUGE difference, but multiple amps cascaded together, will always mildly degrade the original signal to "Some" extent.
Kinda like back in the 80s running your car head unit, into a Kraco booster amp.......
Yes I agree but my intentions with my setup works well with a single sub.And yes, there is a point to having multiple subwoofers. Search for 'distributed subwoofers' and all will be revealed
^^^^^QFT ^^^^^
but apparently this is their argument, the main amp has a signature they want, but miraculously the sub amp has no signature so the signal is unmolested when passed through, now that's funny eh lol. So their plate amp is somehow transparent but their main amp is notme thinks they need a better main amp if their sub's PLATE AMP is superior eh.
First of all, it doesn't matter if the sub is perfectly neutral. If it isn't neutral, it won't be neutral for either line-level or for speaker-level inputs. You seem to think there is some radically different signal path within the sub for speaker-level and line-level -- even though I've already clarified there isn't. There is a step-down of speaker level to create internal line-level, they take the exact same path after that. Regardless of whether the sub is neutral, a different signal in (e.g. line vs speaker-level input) will indisputably cause the sub to have a different output. Which will sound better, or whether there is even be an audible difference, is situational based upon individual equipment, music type, individual preferences. The only "noise" in this thread is from you cherry-picking the "upsides" (which aren't even definitive upsides as discussed in post #23) and ignoring the downsides, so that you can repeatedly declare that line level is definitively better. You should know better than to declare anything as an absolute in audio.
Second of all, there is a very clear and very specific reason why active subs can be very neutral. That is because every single element in an active sub's signal chain, from input to output, is selected, controlled and designed by the sub designer/manufacturer. That totally self-contained (input to output) nature of knowing and carefully choosing every element in the active sub is very different from stereo amp and speaker design where, at the time of the design, the designer has absolutely no idea what the amp and speaker pairings the customer will use them with. If a designer can't make an active sub very neutral, when they literally have absolute control over every single element in the signal path/driver/enclosure, they should definitely choose another profession.
I think you are purposely missing the point we are making. The sub is not the variable, the main amp is. The one you use for the left/right channels, and then have to drop down to go into the sub high level input.
BTW, FWIW, I was in a hurry (this is just a temporary setup) and, since the amp has an adjustable volume control, I plugged it into a tape out rather than using Y connectors between my pre-amp and amp. Meaning I have to adjust the volume on the sub amp when I adjust the volume on the pre, since the output to it is constant. AFAIK, when I hook it up "properly", this problem will go away, but I doubt it. It seems to combine the signals in a way that does this.
^^^^^QFT ^^^^^
People that know a lot more about it than you or I say otherwise.
They are both valid ways of getting signal to a subwoofer.
Adding several extra amp stages, will Never, repeat never improve the signal. Signals subjected to extra circuits can only be degraded.
What matters, is maintaining the actual signal intact, from preamp, to sub amp.
That is an "Appeal to authority" type of argument/comment.
I never said it was not a valid way of getting a signal to a subwoofer.
And in fact, said it probably does not really make much difference either way.
