thedelihaus
Nocturnal transmissions
Hey guys. Last time I took apart the well that the bearing sits in I seem to have lost the seal and oil leaks out. What are you guys sealing the joint with?
Check this post out-
Guys
I want to throw a tip out there.
The PL-41 bearing has a thin paper or fibre gasket that seals the bearing cap, Im assuming to keep the oil from leaking out. Everyone I have seen is destroyed as soon as the bearing cap is unscrewed.
What I did was to take a strip of teflon tape, the kind used in plumbing, lay out about a 6-7 inch piece flat and slice it longways down the middle.
Then wrap the threads of the bearing housing with the teflon tape, i made 2 complete wraps, do this before you oil the spindle and replace the cap.
To do all this I remove the bearing housing 3 screws, and lift out the bearing housing. When the housing is out I clean all the parts,wrap the bearing housing threads with the teflon tape. Then lube the spindle drop that back in. Then add a few drops of oil and replace the bearing cap. You will notice that the spindle will not settle down all the way because of the oil in the housing. What I did was to hold the bearing housing in my hand while pushing down on the spindle tip with my thumb.
Within a few minutes the air and a little oil bled out around the top area of the bearing housing around the spindle as it settled in.
No leakage what so ever from the screw on cap.
Also something to consider I also polished the spindle, using a drill press, very fine crocus cloth, I think 2000 grit then used metal polish till it reflected like a mirror. I also polished the thrust tip, I used a block of fairly soft wood, and liquid metal polish allowing the thrust tip to make an indentation in the block, a few drops of polish in the indentation and then letting the tip ride in the polish, I used very light pressure.
This polished the tip to perfection.
I used mobile 1 synthetic to lubricate my bearing.
bob
