I agree with you that microphonic and noisy tubes wont get any better. I also agree that you cant keep using them because going by your description, it would make listening un-enjoyable.
I just wonder if you are being so enthusiastic about these Russian tubes because when you first put them in, that they worked, and in comparison to your Chinese ones that obviously didn't work due to microphonics and noise, then ergo, the Russian ones are great tubes? I also wonder that if you had received working Chinese tubes to compare to the Russian ones, that you may actually prefer the Chinese tubes as I do?
As it so happens, I did use my oscilloscope and ears. The Russian tubes picked up less airborne noise (checking on the scope - good) , but simply had no top end or dynamics (ears - bad)
The Chinese tubes I got are some of the best tubes I've ever heard period.
Perhaps I got lucky and you got unlucky?
I've heard quite a few Russian tubes of the 6n1p / 6n2p /6n3p variety (I also use them in my DAC) and I can identify a common trait with them that they often have a tight upper mid, and rolled off top end.
Not all of them, but the vast majority that I tried. I don't think the ones I got are defective. They just seem to have the common trait that I am familiar with.
I have heard one or two that were "open and airy" sounding, but still not in the same league as the Chinese ones that came with my Little Bear.
The Russian NOS tubes on ebay come from one of three factories. In my experience the factory and the year of manufacture does make quite a difference.
The Chinese tubes I received, I would describe as the perfect tube. - Not microphonic / open / airy / quiet / tonally balanced / grain-free / extended but not emphasized top end / have explosive dynamics.
My advice to people is to listen to the Chinese tubes first, and if proven to sound good and have no microphonics then leave them.
If proven defective (eg. microphonic) then contact the ebay seller and ask for replacements.
I've said what I have to say. Its simply good advice - effectively, if it ain't broke don't fix it. (alternately, if it is broke, do fix it)
I didn't want to get into an argument with anyone, I just wanted to share my positive experience with the Chinese tubes. I think very highly of them as you can probably tell by now. I'd be really sad if people were just throwing out their working Chinese tubes without giving them at least 8 hours of run-in, and a good listen.
If you are happy with your Russian tubes, then great, I'm happy that you are enjoying your little bear as much as I am.
